I need a better understanding of the reset function for wiring a specific circuit for my dad's shop. I understand simple logic and the concept fairly well (I think!??)
Basically, a trigger on a liquid plastic dispensing gun/pump is pulled, and when the trigger is released, an output needs to be energized 5 minutes after the trigger has been released, (which will set off an alarm to remind to flush the gun), at that point the employee will need to press another switch to reset the system to fill the next mold which will of course also need to stop the alarm from sounding.
It's an extremely simple program until I add this variable - The user could pull the trigger again before the 5 minute countdown is up which needs to start the program again and ready for another mold, instead of setting off the alarm.
If the employee pulls the trigger again before the alarm goes off to fill another mold, (before the resin has started to cure in the nozzle which is at 5 minutes) the timer needs to reset from the most recent mold fill, if in fact the trigger is pulled again before the 5 minute countdown has completed.
After I have a better understanding of how that should be done, I would also like to be able to make the "5 minute" countdown variable, and be able to set at several different intervals such as; 2,3,4,5,6,7,8,9,& 10 minutes, so they can set the alarm to go off earlier in the summer when the resin cures quicker.
I am thinking a relay will latch on which will input a timer, but how should the reset part integrate?
Thank you everyone!
Joe.
Thank you everyone!
Joe.
