sinamics G120 DRIVE
Hi All I have done the commissioning wizzard on the drive with Tia portal V15.1 and all good , but once i go to acceptance test and click on STO...
2,217
Today I have installed a Sinamics G120 250kW Drive(order no: 6SL3224-0XE42-0UA0), communication is via profibus DP from S7-300 PLC. When i start...
1,832
hi every one is t possible to power the (6SL3244-0BB12-1FA0) CU240E-2 PN unit with an external power supply 24vdc without the need of the power...
568
Hi, Small question... Can you see if drives in a TIA project are equal to online in the blink of an eye or is a compare for each drive needed ...
1,506
Hi guys, i was wondering how do i download the parameter to new drive in case the drives die.which software do i use. kindly support and advice...
1,679
