Single Phase Inverter question
eddycheong said:
thx for all the replies..1 more thing how can i change the motor direction..my friend told me he manage to reverse the 3 ph motor by change the hot wire connection to the inverters, but that is 3 ph motor
EDDY
On ANY motor you must change the rotation of the field relative to the armature to change rotation.
3 phase motor on "standard" 3 phase can be reversed by reversing any two motor leads. This changes phase rotation from ABC to BAC thus reversing motor. What happens in the motor is field A energized first (so to speak) then when you reconnected B energized first so that reversed the rotation of the field in the stator.
3 phase motor on VFD can be reversed by reversing any two motor leads OR telling VFD to change firing sequence of IGBTs thus changing phase rotation from ABC to BAC thus reversing motor.
DC motor can change rotation by reversing the armature or the field(s) possibly plural if a compound motor both series and shunt field. You cannot change rotation by reversing the line leads.
Single phase motor can be changed by reversing one of the two fields. The trick here is when wound the field leads must be brought out to the junction box. You cannot change rotation by reversing the line leads.
Dan Bentler
Hello Everyone, I've Delta DVP 20EXPLC. In this PLC, we can generate the pulsed outputs at Y0 and Y1. I wish to do the single phase inverter with...
1,753
Slightly off topic, but I am scratching my head and trying to find a solution for this. Basically a friend of mine wanted to set up a small...
14,409
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
135
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
546
Hi PLCs.net! I'm working on a multi-motor system, most motors are single phase, driven by servo drives. I wanted to check what kind of motor...
1,538
