Sink sensor
SS ELEC
May 2014
Allentown
Hello
I have a 24v 3 wire sink prox switch. I have an AB SLC 1746-IB16 Sink input card. I can't get it to read the switch. It looks to me like the wiring is different. Does anyone know if sink switches are compatable to sink input cards? Or do I actually need a sourcing or 2 wire switch?
Before others chime in about nomenclature of different manufacturers over labeling of current sourcing/current sinking,
I will say that with that input card, you will need a sensor that is a current source (some manufacturers will also label them PNP).
What sensor are you trying to use? We might be able to nail thing down a bit better for you. (y)
Sensor Type
The sensor is an AB 872C-D2NN8-E2. I read on this forum that it is possible to change a sinking sensor in to a sourcing, but I don't understand how. Can you give me infor on that?
You've presumably already worked this out if you made it work with your resistor, but for the benefit of others reading this, using a pull down resistor also changes the polarity of the input - a NO sensor becomes a NC sensor or vice versa
We have a Rockwell 1734 IE8C 8 channel analog input card, but we don't know if this is sourcing or sinking. The user manual doesn't seem to have...
1,169
Got a new piece of equipment that has a flow switch on it. But the flow switch is 4-20ma output and we don't have any analog inputs left and the...
19
5,252
Is there a way to pull the heatsink temp from parameters to the PLC? I've had a couple critical drives fault recently for failed heatsink fans. We...
2,199
Good Day, I do not use Power Flex much and I was called to troubleshoot one at a customer site. So if you have some advice I'd appreciate it...
10,968
Just wondering if it is possible to wire in a Cynergy UF08B100 Flowmeter into an Allen Bradley 1734-IE4C. I have tried every way I can think of...
3,267
