Sink/Source NPN/PNP Delima
dbodenheimer
Aug 2011
Melbourne FL
I have existing equipment that uses both Sinking and Sourcing Sensors. The new control hardware I'm putting in is Sinking only. Is there a circuit that I can use to allow me to use both input devices? I know I can use a pull up resister, but 1. I have to only install it on the devices that need it and 2. It inverts the signal which is not good for photo eye logic.
I know that at one time AB had a circuit inside their I/O that would accept either type of input automatically.
Does anyone either have a schematic of that circuit or a similar one?
Thanks!!!!!
Dave
Mickey,
Thanks for the prompt reply.
What I'm doing is designing an interface board between the old field wiring and the new I/O. I want to incorporate this circuit on all inputs. So I can't use the part you forwarded to me. Instead, I would like to build the circuit directly on my PCB.
Do you happen to have the schematic of the circuit?
Go back to the link Mickey posted. There are two links in the post. Follow the first to find out what kind of circuit you need. Then google for hardware.
Why won't that hardware work for you? The one module performs for both NPN/PNP in to both NPN/PNP outs, giving you universal conversion.
(edit: Its weird how some questions seem to come in twos or threes)
Is this a contest to see who can build the best PCB? Otherwise why do this? Most likely you will eventually either replace the "control hardware" with the proper sinking or sourcing, or replace the field devices to match your control hardware.
The reason is failures. When something goes ka-pooey, the question is going to be "Is it the field device, or is it the PCB circuit"? After 3 or 4 times wrestling with this, you will fix it like you should have the first time.
We have a Rockwell 1734 IE8C 8 channel analog input card, but we don't know if this is sourcing or sinking. The user manual doesn't seem to have...
1,142
Was working on a machine today with a Fanuc 90-30 with some relay cards when I discovered they used the dry contact relay card to sink the...
3,110
hi all,, i want to use npn sensors with (0v output) to my s7-400 digital input module,, what module should i use to detect input to siemens s7-400?
1,505
I need to make a drawing for wiring a 1769-IQ16 module. I have a drawing from AB that shows it will do sink or source. What is the common u.s...
3,161
Last week I drew a drawing to a client base on an old project in my company using the same compactlogix PLC. I asked buddy here, people said...
3,222
