Siprotec 7um611/612
edwaw
Feb 2010
libya
18
hi
i am having problem with SIPROTEC 7UM611/612 "Multifunction generator and motor protection relay" which casuing shutdown of our power plant gas turbine on reverse power shutdown!. this shutdown should only be intaited with turbine mechanical failures only but its not the case. please help
best regards
Hi, Anybody ever made a system with DNP3 exchanges between RX3i PLCs and Siemens Siprotec 4 devices ? I'm trying to do so but the PLC always...
1,370
Hi all I am trying to connect a siprotec relay 7UM61 to s7 300 on profibus the siprotec has standard mapping 3.1 68 bytes input 8 bytes output...
3,716
Hi, In one of my projects i am using Siemens Siprotec Numerical Relays (7SJ611,7SJ641,7RW600) for IEC-103 communication with Telvent RTU. I have...
9,495
Hello, I come here to get some help on my search for one or more problems on my machine. I am totally beginner and I am currently discovering...
54
13,314
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,679
