SkyCAD Electrical
I'm bouncing back and forth between Skycad and Design Spark Electrical to see which one I like the best. Both are good programs and both are free. :)
Every year or more I install it do something quick then forget all about it. Last install was over a month ago and it looks pretty good that I spent a couple of hours watching tutorials. Next project I will try it out for the whole thing.
I've done this as well. Seems really powerful but also requires a bit of time upfront to set up your libraries etc.
I think this is the kicker with any software really... if there are libraries for it where one can just start designing stuff it's fairly simple. The issue is always drawing the libraries and getting the aspect ratio correct as well which takes a lot of time.
I strongly recommend SkyCAD Electrical.
They really created a nice piece of software, that was designed different from its roots up.
Very sophisticated, but yet user friendly, features. Since the one that lets you add a device (a contact, for example) to a line without you having to cut the line, making room to the device, and redrawing the line around the device; all the way up to the catalog, the panel design, the terminal blocks, etc., etc.
Their tech support is fantastic, and they are open to your ideas for new features and things to fix/improve.
Their standard version is free, and their paid versions are more affordable than others with less features.
Definitely worth a try!
I’ve been using it for almost everything the last year or so. It has it’s quirks like every software program, but it’s really starting to work well for me. Now that I have most of my common parts built up, I can generate drawings and BOM’s in short order
Another reason I stopped using Skycad is that I was getting random crashes out of nowhere. It seems to have been isolated to me, as Skycad support was kind of at a loss. That's definitely one positive I've encountered is that their support is very quick to reply and don't seem to just give you the generic steps to try.
Hi everyone, I'm in search of software for electrical drawings, preferably free but also interested in paid options. Any recommendations or...
33
1,611
Hi Expert: I have used EPlan at previous job, now in the new job they use AutoCAD Electrical, just finished one training at Udemy, it is not good...
1,163
Hello, I am running a AMCI SD4840 Stepper Motor drive system with Allen Bradley CompactLogix. Every now and then when a 480VAC motor kicks in on...
595
Good morning, we have a lot of coolant mist around our machines and sometimes the fans on the drives inside our electrical cabinets will suck the...
1,310
