slc 150 to RS Logic
vf816
Oct 2009
il
72
Good morning forum
I have been trying to convert an old SLC 150 program to a RS Logic 500 program. And I was hoping for some feedback on what I have done so far. (I am still in the learning process) Attached is what I have completed so far. And the first half of the original file. I will post 2nd half separate to large as PDF to do at one time.
The machine is an empty bottle De Palletizer. It is loaded with a pallet of bottles 300-400 per layer 10-13 layers per pallet .They are swept off onto a hoist elevator one layer at a time which lowers them down to an accumulation table. Where they continue on into the filling room.
Thanks for any and all feedback.
Jeff
Jeff,
After only having a brief look through, one thing I would suggest is trying to break up the program into smaller program files.
So rather than having one program file with every bit of code in it, split it into smaller more manageable program files that mean something.
This will make it far easier for fault finding etc.....
Mark
This is why I am here I always learn something useful.
Thank you.That make perfect sense.
i would also split the file data structure into different files also.
use the b3,t4,c5 files for general use
station 1 - b13, t14,c15,r16
station 2 - b23, t24, c25, r26
see the pattern. that way, if you have 5 stations that are identical, you only have to learn only one station.
Dont forget RUNG COMMENTS - very inportant
We use all caps - many of the machanics (myself included) don't see as well as we used to.
regards,
james
How can I get a schematic for it? I am unable to communicate to it using PCIS with a 486 PC and suspect the SLC150 to be faulty (found in a junk...
3,118
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,155
Hi, I have an old SLC 150 processor that is throwing up a CPU Fault light. I have an EEprom program chip for it, but I can't get it to load up...
2,346
We have 3 SLC-150s that we are using, we would like to create a print for them and diagram the program so when we get approval we can replace them...
2,656
Hello, I am completely new to PLC's (and forums) and have been tasked to repair/upgrade a conveyor system at my college. It currently has an Allen...
2,696
