SLC 5/03 communication problem
hiten123
Apr 2007
Aurangabad
I am a novice to PLCs. I have with me RSLinx and RSLogix 500. Now I have connected the SLC and the PC thru a serial cable. I went to RSLinx and tried to configure a DF1 driver. When i press the autoconfigure button, it is unable to do it and asks to check the communication link. I know this cable is good. Is there anything else i have to do to make this work?
The cable between an SLC-5/03 RS-232 port and your computer's RS-232 port must be a "null modem" type cable.
The A-B part number for such a cable with a 90 degree connector on the controller end is 1747-CP3.
It is possible that the serial port of the controller is not configured for DF1 Full Duplex protocol (which is the default) and therefore you must use a different RSLinx driver (1747-PIC/AIC+) or a different connection method.
Hi All! At the start I have to say I am new here, so if I do something bad, just tell me ;) I have huge problem with SLC 5/05. After somebody...
18
2,871
Hi all. I have SLC 5/05 PLC which is kept for years as it is without using. I have been asked use the same plc for testing by downloading the...
27
6,115
Hello all, I’ve run into an issue when replacing an existing PanelView 900 (2711-T9C8) with a new one. The PV is networked to a SLC 05/04 using...
1,978
Hi all, it's my first thread in this forum. I have problem with eem instruction. I try to communicate my slc 5/05 with alarm system and all time I...
3,817
Dear all Respected Masters.. I m facing very strange problem regarding SLC 5/05. I m running Windows XP in my Laptop. I have RSLinx, RSLogix 500...
8,063
