SLC 5/03 Ethernet with SNMP
sgocken
Aug 2009
Iowa
I have a SLC 5/03 and want to add an Ethernet interface to the rack. My main goal is to get SNMP support. I have been looking though docs for days and the only solution I have found was to move to the SLC 5/05. Is there a cheaper option?
It really depends on what you want to get from SNMP. You can use a serial to ethernet converter that is SNMP capable and monitor connection health but you willnot get anything aht is PLC specific.
What I really want to do it to get the state of inputs/outputs.
I have an old alarm panel (made in the late 60s) that lights alarms for the building. I want to build that alarm panel in a website that will e-mail alarms. The website part is no problem for me and I do a lot with SNMP. The hard part is getting the data. SNMP traps would be the best, but I can do SNMP get as well.
Hello all! I have some machines that run an SLC 5/03 and occasionally a fault is generated. Recent Example: A power supply wasn't screwed in...
435
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,654
We are replacing a piece of machinery with a newer version. The new assembly has 5 TCs which are closer by far to the operator station than the...
2,279
Will a PVP7 talk to an SLC 5/05. I can't get them to talk. I have set up PVPs to Control and Compact logix plenty of times, but can't get these to...
2,533
Hi all I have a legacy PLC (1747-L552C) and I have been asked to look at remote access (it's communicating via ethernet to a PVPlus6). I have an e...
1,546
