SLC 5/03 to ML 1100
stasis
Mar 2005
Columbus, Ga
344
anyone know of a decent DH+ to ethernet converter? Any tips?
I'm working on a project where I have to get a 5/03 w/ 10 slot rack to communicate with a ML1100.
All 10 slots are used and because of costs, modifications (read: AB hardware, extra rack, etc.)or upgrades are not an option.
Do you mean a 5/04? To the best of my knowledge the 5/03 doesn't communicate via DH+.
If it is a 5/04 it may be tough. You won't go from DH+ to anything for a low cost. You may not want to hear thins but your best bet is to go with a 5/05 and go direct Ethernet or go with a 5/03 and a NET-ENI or similar and go DF1 to Ethernet.
Keith
Hi there, as the title suggest I was hoping that someone could help me out a little bit. I am currently updating an pallet trolley system from...
1,317
Hello Friends I have gotten a UDS1100 to connect a 5/04 PLC to Ethernet through serial port. I have set the IP address in the UDS1100, but I can...
2,169
Hello Friends I need to share some bits and integers between SLC 5/04 and a ML1100. I am thinking in Lantronix UDS1100 connected to a switch...
2,128
SLC 505 L551 OS501 FRN11. CIP (ethernet) MSG-READ from 3 seperate Micrologics 1100 B .IP's are correct (the PV 1500 reads the F8:0 address from...
1,843
i have a 505 and a micro 1100 on the same same network. how can i set an output on the 1100 when i have a bit to go high in the 5 05? thank you:hmmm:
1,586
