Well, the poll has the PSU (7 votes) just edging it from Operator Error (5 votes) - so, on that basis alone, it could still be either
Although still not ruling out the Operator Error option, I am erring towards it being the PSU as the cause of the problem myself now though.
As much as I didn't like doing it, I powered the PLC off/on lots of times today and managed to get some fairly reproduceable results.
It would help if I knew what was supposed to happen, but anyway..... According to the manual the P2 PSU is supposed to be able to hold up power for between 20ms and 3000ms depending on the load. Given that I have just the CPU, BAS, 1 IB16 and 1 OW16 installed, I'd expect the hold up time for me to be at the higher end of the scale. (The CPU Backup battery is reported as being good).
Test Results
Powered off the PSU for 20 seconds on 10 consecutive occasions - the system failed to recover every time and "hard" faulted. During this time, I discovered an apparently reliable way of recovering the PLC after each failure. If I power down for just as long as it takes for the PSU power light to go out (~1sec), the system recovers every time. (This is what I did between tests).
Powered off the PSU for 60-61 seconds on 10 consecutive occasions - the system recovered every time !
Powered off the PSU for 3 seconds on 10 consecutive occasions - the system failed to recover every time.
So, either power it off/on very quicky (1s) or leave a longer time before powering back on (>60s).
One anomoly in the testing though, when powering off for ~5 seconds on 10 consecutive occasions, the system successfully recovered ~50% of the time !
Don't know if I'm missing something about how the system recovers from power failure, but these tests lead me to believe that it is a PSU fault,
Regards
Dave
Test Results
Regards
Dave
