SLC 5/05 communication with Powerflex 700 drives
SPARKYMG
Mar 2011
Ontario
Could I have some opinions on the best way to integrate powerflex 700 drives to an older SLC 5/05 on ethernet. From what I am being told the MSG function from the SLC to the drive needs to be scheduled one at a time which will cause drive performance delays. I could have 9 drives starting at once and cannot afford any communication delays. Another option I hear is to install a compact logix controller to control the drives and MSG from the SLC to the compact logix controller apparently here I only need one MSG instruction to send to the compact logix controller. The other option put forward is to hardwire the start, stop signals and analog output signals for the speed reference. I do not have any programming experience and would appreciate your thoughts for the best integration without performance loss. Thanks for your time.
I thought there is a way to broadcast a message to multiple devices but I’ve never had to do it so I don’t know how.
I too have just inherited a project do this. I'll let you know if I find anything usable.
Hi all, I have been asked to build a panel with 7 Powerflex 4 drives. AB Panelview 550 SLC 5/05 with digital inputs, outputs and analogue...
11,393
Hello, I need to connect with a SLC 5/01 (1747-L511) in order to see what is the current program that it has, since I don't have a lot of...
717
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
432
Hi all--figured I'd knock the rust off minds here; Situation--We're resurrecting an old Alvey Palletizer from the grave. It came w/o a controller...
956
Hey everyone, I am trying to communicate with a Slc 5/04 plc using the 1747-cp3 cable, RS232-DF1 driver and a laptop. I tried using a serial to...
3,121
