SLC 5/05 ethernet
maxcastaneda
Jan 2007
monterrey
Hi guys!
Any of you has succesfully communicate AB slc 5/05 using the ethernet port with VB.NET or VB6?
We created a driver for comunicate with the serial port using the DF1 protocol in VB.net, but with ethernet port, the things seem to be different.
Do anyone have experiemce with this?
Thank you.
I have been looking into this and hope to write an open source driver over the next 6 months.
I have found that two protocols exists on the 5/05. One is supposedly a DF1 protocol wrapped in a TCP packet. The other is based on the CIP protocol or Ethernet/IP.
I found a document on www.odva.org that explains the protocol concept. It will clearly be no easy task to implement the protocol from their documentation. The document is not even the latest, apparently they want a good chunk of money for the latest version.
If you get any better information or care to share source code I would be very interested.
I have several programs communicating between the SLC505 and VB6.
I use a software package from Automated Solutions for my drivers.
This driver also works with the CompactLogic L35E and the ControlLogix ENBT module.
I have done this using delphi to PLC5, SLC5/05 and MLX 1500 on a NET ENI quite successfully using the Automated solutions activeX package.
Hello all! I have some machines that run an SLC 5/03 and occasionally a fault is generated. Recent Example: A power supply wasn't screwed in...
424
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,611
We are replacing a piece of machinery with a newer version. The new assembly has 5 TCs which are closer by far to the operator station than the...
2,260
Will a PVP7 talk to an SLC 5/05. I can't get them to talk. I have set up PVPs to Control and Compact logix plenty of times, but can't get these to...
2,508
Hi all I have a legacy PLC (1747-L552C) and I have been asked to look at remote access (it's communicating via ethernet to a PVPlus6). I have an e...
1,544
