SLC 5/05 Serial vs. Ethernet
smohamed
Mar 2008
ON
108
A quick question. I configured my SLC 5/05 through the serial port and then downloaded the program, such that I could use the Ethernet port to communicate. I have it all working on my network, but this is more of a general question.
I understand that the Serial port is Channel 0, while the Ethernet port is Channel 1. However, within System Comms, through RSLogix500, when I select the DF-1 Driver, it shows
Node 1 (RSLinx API is the server) while when I select the Ethernet Driver it shows Node 0. Is it because my computer is Node 0 with the serial driver?
Could anyone clarify this for me?
Thanks!
Probably. If you open up the DF1 drive config in RSLinx, you will see a field for "Station Number". I'm betting it is set at 0.
In any event, the RSLinx 'Node' has nothing to do with the physical port, it's just a means of addressing multiple devices.
I am needing to connect a fixed style SLC-500 to an ethernet network for data collection to an OPC Server. I see the Fixed Style SLC-500 has an...
2,575
I have an Allen Bradley SLC 5/05 in my location and I want to connect it to my PC to configure a new CPU 1747 L552 in its rack. But, the serial...
21
9,275
Has any ever used a generic (off the shelf) ethernet to serial converter to communicate to the DF1 port of a SLC500 ? The Allen Bradley NET-ENI...
2,224
I have just started with a new company and they want me to look at some logic in a automated system using a SLC 5/05 processor, 3 input cards and...
14,195
I'm trying to get comms to a SLC CPU 504 using a moxa gateway EIP 3270. I can use their Procom software which sets up a virtual comm port so...
5,324
