Slc 500 - 1746-ob16 / d
Automater
Jul 2014
SPain
47
Hello,
I have a few boards, the same, which are: 1746-OB16/D
It seems hard to find the manual online. Any help with that please.
My question.
I have connected 12v+ to the VDC and 12v- to the DC COM.
The board gives out a 12+ from OUT1 / 15. Is there any way to change it to a 12- (NEG)
Thank you
Page 24 of this manual:
http://www.icmaster.com.hk/PDF/1746-in027_-en-p.pdf
shows the OB16 to be transistor output sourcing - meaning that +24 VDC is switched through the card to your device which has 0VDC (NOT -24VDC) connected to the other side of your device.
Maybe you want a sinking output card where you supply +24VDC to the device and the card switches to connect it to 0VDC thereby completing the circuit. that would be similar to 1746-OV16
So i have a 1746-NT8 thermocouple for a conveyor furnace that is causing some problems. When the CPU is in run mode the channel 6 LED flashes, but...
1,612
Hello, We have an old SLC 500 that has two 1746-HS Single Axis Motion Control Modules. One of these modules is bad. Verified by swapping out a...
1,169
Hi everyone.. I have 1 basic module SLC 500(1746 Bas), now i want to back up programmed (upload), but i dont know to cumunicate with this...
4,718
Hello all. I have an output module that I'm trying to wire-in and don't know if the module is bad or if the installer (me) has done something...
26
8,646
Hi, I want to set up a remote I/O link between an SLC 5/04 and a remote I/O rack which would be about 100m away (cable distance). I know that I...
3,651
