ceilingwalker
Hello all. I have an output module that I'm trying to wire-in and don't know if the module is bad or if the installer (me) has done something wrong. I went to the IO config and found my module toward the bottom. I installed it in slot 10 (only slot of 12 that was open). I found this module lying-around our shop so I'm not even certain it works. According to the drawing I found, I'm to connect my +24VDC to the "VDC" terminal and my 0VDC to the "DC Com" terminal. I have an MMI that turns on the input (not a discrete input). While online and I push the on button, the output shows that it's on, on the ladder, however, I'm getting no voltage when I put a meter on either the VDC or the DC Com, and the output terminal (O:10/1). I've never a sinker DC output board before and I'm not sure I have done it right. Anyone that could help, I sure would appreciate it. Thank you.
