suboliu Member S Join Date Oct 2010 Location windsor Posts 266 Oct 30, 2010 #1 if I want to send a value of N file to slc. after I set a block trans. on panelwiev. how slc get this value. because slc hasn't Block trans instruction to receive this value?
daba Lifetime Supporting Member D Join Date Jul 2004 Location uk Posts 5,401 Oct 30, 2010 #2 You have almost answered your own question.... ...the SLC needs a BTR instruction to receive the data from the PanelView BTR data-block.
suboliu Member OP S Join Date Oct 2010 Location windsor Posts 266 Oct 30, 2010 #3 daba said: You have almost answered your own question.... ...the SLC needs a BTR instruction to receive the data from the PanelView BTR data-block. Click to expand... thannk you answer my question! but SLC hasn't BTR instruction!!!
daba Lifetime Supporting Member D Join Date Jul 2004 Location uk Posts 5,401 Oct 30, 2010 #4 Which SLC ?
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Oct 30, 2010 #5 daba, Before you get to involved see his other thread. http://www.plctalk.net/qanda/showthread.php?t=59056
suboliu Member OP S Join Date Oct 2010 Location windsor Posts 266 Oct 30, 2010 #6 daba said: Which SLC ? Click to expand... thank you very much!!! but i did not find this instruction in manaual
daba Lifetime Supporting Member D Join Date Jul 2004 Location uk Posts 5,401 Oct 30, 2010 #7 suboliu said: thank you very much!!! but i did not find this instruction in manaual Click to expand... It is definately in the manual...
suboliu Member OP S Join Date Oct 2010 Location windsor Posts 266 Oct 30, 2010 #8 daba said: It is definately in the manual... Click to expand... yes, I found. thank you very much.
