SLC and temperature control
shocker1898
Apr 2005
I am wanting to control some heaters with my SLC 5/03 but instead of using regular temperature controls I am going to use a 1746-NT8 (termocouple card) and a 1746-NI4 (analog out put card) I am also using Watlow SCR's with a 4-20ma input. the question is I want to be able to control these SCR's like you would in a standard temp control, but just using the SLC does any one have examples of the PID loop I would need to use and also does any one have any Idea on how to Auto tune?
Shocker
shocker1898,
Do a search on the forum for smc or hot rod. You will get plenty of info.
Bob O.
Temperature is typically a slow variable to control. IMO it would be simpler to use solid state switches and pulse width modulate them from the PLC. You can even get away with a simple band control (maybe 3-4 error ranges) that result in differenct duty cycles to the heaters. In other words, high duty cycle with large error and smaller, but adaquate duty cycle when close to setpoint.
Yes, but...
Shocker
First checkout the hotrod.zip in the download area.
It took years for me to learn how to do an auto tune. Your question is like Grass Hopper asking master Po on Friday if he could learn kung fu in time for the Saturday night bar fights.
Unless you really want to know how to autotune something you should consider a heater controller with auto tuning built in.
I have been asked to upgrade a packaging machine using a SLC 5/04 and was wondering which is easiest to use, 1746-NT4 or 1746-BTM. The BTM is...
4,557
What would the forum agree to be the best way of achieving temperature control via a slc 500 plc.The application is electrically heated via solid...
5,037
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hi to all Again I have a frezzer tunnel that used liquid nitrogen to freeze product. I have to redesighn the tunnel because it looks like it came...
3,433
I have a Temperature transmitter connected to a type "J" thermocouple. The output is scaled 0 to 400 deg. F at 4 - 20ma. This output is going to...
4,092
