slc btr/cop instruction
keving9
Mar 2004
33
I'm trying to do a block transfer using the cop instructions per the examples in the 1747-sn manual. There is a SLC5/03, 1747-sn ser.b, 1794-asb ser.c and a 1794-ib16. The 5/03 can't use the btr instruction. I realize I don't need the block transfer to see the ib-16, I'm using it to keep things simple for the time being, analog modules will be used in the end. The sn module has both switches on and the asb module has all switches on. I couldn't find specific switch settings for the asb ser.c, but according to a backwards compatible bulletin to ser.b, I think those are the correct settings. I can see the inputs change in rslogix but can't make a block transfer work. It returns the BT timeout error.
The file is attached. It's basically the example in the 1747 manual.
Thanks for any help.
file:///C:/WINDOWS/Desktop/SN.RSS
Hi , I have an SLC 505 that I made some changes to. After the changes were made the BTR and BTW instructions became extremely slow. I did not...
1,712
Anyone have the AB tech document that is locked out I have three 1794 ASB miodules (E) and and they are all communicating to 32 point input...
2,160
Setup: SLC 5/05 with three 1747-SN Modules in Main Rack. Two of the three modules are controlling about 23 Powerflex 70 Drives (10 on one...
5,880
Reviewing customer provided SLC layout and has an abundance of RIO devices...So many in fact that I want to understand clearly any limitiations or...
4,750
Hello I have a problem with configuration the Flex I/O profibus module. I have a PLC SLC 505, Profibus scaner on PLC Rack [SST-PFB-SLC] -...
38
