SLC I/O Read Config
Christoff84
Jun 2006
Cambridge, ON
407
We installed a new rack today to one of our SLC 5/04 units. When we did the read IO config, it came back with some wierd settings I've never seen before. If we clear out the modules from the empty slots it faults. If we leave them in, it runs. Anyone seen this or know of it? It's a first for me.
Only slot 23 has a card in it, the rest of the slots are empty.
Do you have an EEPROM?
Maybe the CPU gets loaded from an existing EEPROM on power up and expecting to see the "old" configuration
I've never seen an empty slot reported that way.
WAG: Could there be something mal-connected on the rack extension cable? Or is there perhaps a power drop or break somewhere along the backplane or its connectors?
Thirty addressable slots is the SLC standard. You can physically connect chassis that add up to more than that, but you can address only 30 with a CPU or a 1747-ASB or 1747-ACNR15.
I did find an RA Knowledgebase document suggesting that the light loading of a single module in a large expansion chassis could have an impedance effect on the backplane bus that results in it detecting those "ghost" modules.
http://rockwellautomation.custhelp.com/app/answers/detail/a_id/6209
You might have better stability with a 4-slot chassis to house that one module, or install any future planned modules now.
Thanks for the reply Ken, I can't seem to see that article, says its locked even though I am logged in under my direct connect account.
I will add a few more cards to the rack and see if the errors disappear, we'll probably endup using them eventually anyway.
They're probably updating that technote. That has happened to me a couple of times too...They are finally updating the particular note I need to solve a problem right now!
Gosh I am spoiled. It must be a massive undertaking for the folks at RA to keep up with all the documentation they provide. I do see perceptible improvement, and I have used the feedback system and gotten excellent interaction from them.
Ken, have you had a glimpse of the new website?
Hello, I inherited a control system one of my predecessors thought it was a good idea to put logic for cant optimization and Kinetix motion...
3,608
Hello. I have a new 5069 L320ER that I installed and I am trying to read and write data to an existing SLC5/05 via Ethernet. They are both on the...
2,611
Hello, I have a PID block in my program controlling pump speed in order to get a correct Differential pressure. The way I have it set up is the...
1,265
Hello I was needing to stop one device and start the second device at a certain time each day, for example 10:00 am each day. I thought the best...
5,259
Good Evening , I'm finally understanding a MSG instruction a little better. My question is , I'm using a MSG read in a CompactLogix to see...
1,924
