SLC serial communication
betamax6
Oct 2006
manila
21
can anyone help me with this...
i need to trigger a certain bit on AB SLC program from a pc using RS232 protocol, how do i do it? also, can a program created using RSlogix500 be opened by RSlogix5000?
hi again,
just a follow-up question...the plc has this DH+ terminal, can i use it instead of rs232 for the same purpose of controlling a bit or data memory?
Yes, you can communicate to a slc5/04 via DH+, this is done regularly. You'll just need the correct drivers (RSLinx OEM, for example)
And to answer one of the questions from your original post, NO, a program created using RSlogix500 cannot be opened by RSlogix5000. RSLogix is for the SLC 500 family; RSLogix5000 is for ControlLogix/CompactLogix.
The Visual Basic driver pointed out by Mickey will also work over DH+ by using a converter such as the 1770-KF2 or a DataLink DL3500.
Also if you search for AdvancedHMI on sourceforge, you'll find a package that includes a newer version of the DF1 driver and it also comes with some graphical components that work with it. These are all open source, so everything needed to use them are freely available.
You may want to watch these, they give a quick intro to both projects:
http://www.youtube.com/watch?v=CiPzqc5jDlE
http://www.youtube.com/watch?v=P-E8NlUNiX4
Dear all Respected Masters.. I m facing very strange problem regarding SLC 5/05. I m running Windows XP in my Laptop. I have RSLinx, RSLogix 500...
8,048
I have an SLC500 1747-L541 running OS401 and I'm having a problem with serial communication once I have completed loading a ladder to it. RS...
65,048
Hi all, I am experiencing a 'wierd' issue with serial port on a SLC 5/05. The processor is new out of the box. I had previously loaded a program...
64,750
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
696
Hi guys. I have a system we work on. It's a SLC 5/05 at a battery connected through CH0 to a serial radio to a L61 Control Logix processor...
2,111
