slc5/03 and NET ENI
balash
Dec 2012
Koprivnica, HR
418
Hello,
I have SLC 5/03 that is using rs232 (DB9) port for radio link comm. now i would like to link it also to er75i gprs modem as i have ethernet driver for WinCC and some ML1400 are connect through it on SCADA.
My idea was to use one spare NET-AIC module and one spare NET-ENI module to get Ethernet from RJ-45 DH485 port (programming port).
Would that work is what i'm wondering, and if yes what is the cable pinout for interconnection between NET-AIC mini DIN and NET-ENI mini DIN?
I guess that RJ45 uses 4& 5 pin for DH485 A & B signals
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
939
Hi, I am setting up a new Ignition scada project and the only PLC is a SLC 5/03. I have the SLC connected to a NET-ENI via DF1. I have the...
3,406
Hi all, I have a redlion I am trying to connect to a Allen Bradley SLC5\03 via a 1761-NET-ENI which i seem to be having no luck getting comms...
4,676
Greetings, We have a site that has 2x SLC5/04's that are connected via DH+ through to an archaic Scada system. We are in the process of upgrading...
1,714
I am able to connect a laptop, SLC5/03 and a PV600 via a NET-ENI module and see the PV600 and make online changes to the PLC. The problem is that...
4,206
