SLC5/05 Ethernet communication
spencer977
Jul 2006
Hamburg
Hello ,
I`ve got a small question :)
I have here one SLC5/05: 1747-L552 CPU. Now I want to move
the received ethernet data to the N12 data file, and want
to send from N13 the data back to the ethernet.
On the other side is one PC with an C++ Applikation and
the allen-bradley special .dlls. (This has already worked
on an PLC5 system)
So I only want now know how I can receive and send these data.
Greetings
You need to re-configure your C++ application to communicate with the SLC 5/05. This may be a different parameter in your comms command or you may need a different driver.
what are you using as your communications driver for the PC?
the addressing should be the same.
Hello:
I use the following programm:
It is an Software package from "Ingear"
www.ingearopc.com .
I use here only the activX control and
write down directly to the N12:4 (Lenght 8 Bytes)
and read from the N13:4 (Length8 Bytes)
Is the ethernet connection the same from PLC5
and SLC systems, so I can use the programm for this SLCs?
Greetings
did you change InGear settings to talk to SLC ?
Oh, i`ve give me self the answer.
"The person who can read is in advantage of the other"
On the webside of ingear is a small description about
the available controlers
CU
yes I have seen it, after I have read the descripion, from ingear.$
I changed it. Thanks a lot for your help.
Now it works properly, and I can communicate with the pc.
thanx :)
Dear All, I wanna get the data from ind331 indicator(Mettler toledo) to SLC 5/05 CPU via Ethernet Ip using EEM instruction. The CPU=1747-L553...
2,182
Im have some difficulty going online with 1747_L552 controller. Perhaps im missing something and i hope someone could assist me.. Here is my...
3,791
Dear All Please let me know the procedure of communication betwenn SLC5/5 and wonderware on ethernet (TCP/IP). Which driver i need to install...
3,331
Hey Everyone, I need to Interface Ignition SCADA ethernet network to an Allen Bradley SLC5/04 Serial RS232 DF1. Has anyone out there found a low...
1,018
I have a little problem. I have a number of now classic SLC5/05's with which I am hoping to connect to Weidmuller ER20-FCB-EIP I/O nodes. I have...
1,852
