Slc500 1747-l40
unsaint33
Sep 2019
MInnesota
118
I'm trying to program a SLC500. It's 1747-L40A.
I looked up an online manual and it sounds like this model does not have the internal calendar clock tags I can use. I just wanted to confirm. Using RSLogix500, I created a new RSS file then selected this model as the controller but the tag address editor still lists S39 ~ S44 as if those tags are avaiable. But if I use any of tags, I get an error (excessive element numbers)
Also, on the same RSS file, I cannot chose the 1.0 timer base. It only lets me select 0.01 or 0.001 timer base otherwise I get an error when I verify the program. Also it does not let me set the timer preset more than 100000. Am I doing something wrong? Or is this PLC just a very old model with many limitations?
I'm trying to program a SLC500. It's 1747-L40A. I looked up an online manual and it sounds like this model does not have the internal calendar...
1,202
Hello everybody, I have a slc500 1747-L40C PLC has a similar port of the ethernet port but it is a DH485 port, I want to convert from DH485 to...
1,728
We are trying to connect to an Allen Bradley SLC 500 Processor 1747-L40A with a 1747-PIC box. PIC box to laptop connection is with 9-pin to...
4,063
Hello all, I am doing a migration from two SLC500 PLCs to Compactlogix 1769-L36ERM. At present there are two SLC500 PLCs that communicate over...
4,281
I have a SLC processor communicating over ethernet and was wondering if it is possible to add a PLC 5 to the network using DH+/DH-485 through...
2,678
