SLC500 (1747-L40C) 0002 Fault
Eric Nelson
Apr 2002
Randolph, NJ
4,346
Just got back from a customer with an L40C (SER C, FRN 6) that immediately faults at powerup. I can download the program, switch to RUN, and it works fine. As soon as power is cycled, the fault LED flashes. When I reconnect, I get the dreaded 0002 fault (attached).
This PLC is running a simple material handling system (~70 rungs), and they have a few identical systems elsewhere in the plant. There is no expansion chassis, just the main unit. I noticed that there is no EEPROM or battery installed in this unit (factory jumper in the battery connector). The other ones have a battery (yet no EEPROM). I borrowed a good battery from one of the other working units, but I still get the same fault every time I reload the program and cycle the power.
Before I head off to eBay for a replacement, I just wanted to ask if there was something stupid I was overlooking... :confused:
-Eric
Hello everybody, I have a slc500 1747-L40C PLC has a similar port of the ethernet port but it is a DH485 port, I want to convert from DH485 to...
1,697
Hi guys, I have a SLC 500 1747-L40C. This is a “brick” type PLC. I’m not quite sure what the issues is with the PLC but customer states that the...
2,703
G
I am new to this. I have a slc500 1747-l40c plc, and do not know how to connect to the dh-485 port on it. Can i use a straight cat5 cable and my...
15,459
I'm trying to program a SLC500. It's 1747-L40A. I looked up an online manual and it sounds like this model does not have the internal calendar...
1,188
640
