SLC500 5/05 cannot apply 100Mbps full duplex
zygler
Mar 2009
Bangkok
I use SLC500 5/05 in my process but I cannot apply the Processor run on 100Mbps. I config it to use auto-negotiate but the processor still run on 10Mbps half duplex. Anyones can recommend me how to? Thank
Some of the older 5/05 cannot run above 10Mbps. Make sure your unit has a new enough ethernet daughterboard.
Can you post the firmware revision on the 5/05 label?
Compare that with what is shown in RSLogix 500.
:( any help from you pros is welcome. im running windows 7. i downloaded an emulator and that works but i cant connect to plc via laptop. Im...
1,089
I have a SLC5/03, 1447-L532B 16K mem I dont know much about AB PLC but have a problem with a SLC. I can access registers under F8:63. The...
2,234
Hello, I have my ethernet/ip driver configured (AB_ETHIP-1) and set to the correct card/address on my computer and, furthermore, can ping the ip...
1,739
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
261
can the slc500 5/05 send a email and text over Ethernet ?
189
