SLC500 5/05 Multiple Barcode Messages
jrwb4gbm
Apr 2002
NC
2,245
I am trying to barcode scan 5 cartons and then combine them into a group to send out to an Access database. The database recognizes an askerisk to separate them back out. Each barcode scan uses 16 ASCII
characters plus some additional characters for other information for a total of 12 words.After the group has been sent I need to clear the data and start a new group. I am using a Prolinx DF1 to ASCII port expander that uses the DF1 port in System mode. This will not allow me to use the port in ASCII User Mode, which adds another problem. Can anybody point me in the right direction on how to build a ladder to do this? I am using the standard RSLogix500 software.
Thanks,
Sid
Hi All, In an SLC500 system, with more than one rack, what is the Rack/Slot/Bit address format? I know that the first slot in a rack...
4,880
I have a short line with 3 AB PLC504's connected with DH+ and would like to connect a Panelview 1000 to them. Is the Panelview capable of...
1,497
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
259
can the slc500 5/05 send a email and text over Ethernet ?
187
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
391
