SLC500 Conversion To CLX5000 'Unused Memory'
ian.smith7
Aug 2002
UK
145
Hi All
I have just started a project to convert one of our machines from SLC500 to CLX5000. One of the first steps in the Rockwell guide was to run a 'Delete Unused Memory' Instruction on the SLC program. When I looked at the memory areas being deleted I found that some of it was actually referenced by devices on the network but not within the SLC500 CPU.
My solution is to create some rungs of code referencing memory above that which I need to keep, just a move instruction to a Garbage register.
my questions are
Is this 'Delete Unused Memory' step really required
Is there a better way to preserve these internally unreferenced memory areas?
cheers
ian
No, its not required; it may help conserve some memory in the conversion. But if it is like you describe, memory accessed by other devices, I would probably leave it alone if those devices are going to be re-directed to the same tags in the new CLX memory.
There is not a SLC out there that won’t fit in an L71 so I wouldn’t bother. I just got done converting a 553 with only 500 words of memory left and the L71 still had about 60% memory left.
Thanks for the reply,
Any other advice to pass on i am a little concerned about the IO Mapping.
If a 16 bit (INT) hardware input register is mapped to a 32 bit DINT and all 16 bits of the INT are on. Will the MOV instruction Take bit 16 of the INT and Map it to Bit 32 of the DINT Turning BIT 16 of the DINT OFF (Treating it as a negative number)? Should I use COPY instead?
Also where the SLC had a 32 Bit Input card It was contained in two consecutive INTs. After Conversion the hardware IO has 1 32 bit register but the soft IO has 2 Consecutive DINTs. To get round this I used a SWPB instruction for the High word exchanging the two Higher Bytes into the lower bytes of the destination Soft input DINT. Is that instruction OK to use Is there a Gotcha?
Cheers
Ian
Has anyone used the tool from Schneider to convert an RSS file for an SLC to Unity Pro? Curious to know how it went. Their sales brochure made it...
1,385
Hello I am relatively new and working on converting a piece of code from logix 500 to logix 5000. I used the conversion tool and it did a pretty...
2,454
I am working on a conversion from a SquareD PLC to a SLC series PLC. I have run across one issue that I can not seem to overcome. The older system...
1,677
As an OEM we are always changing our control systems to match our customer's spec. (Don't tell everyone but we even change the colour of wires and...
5,446
I am upgrading a 5TI to an A-B SLC500. I have a printout of the orig. code but am unfamiliar w/ how a few of the instructions work: Question...
2,924
