SLC500 Long Scan Times
mjp123gp
Mar 2012
Savannah, GA
94
I have a 1747-L552 that has been getting occasional scan times over 1 second. The normal average on this processor is around 20ms but about once a week I can check the status page and see the high scan time. It's been running about a week now since I reset the max and it hasn't done it yet.Any ideas what would cause this? Could I add logic to each routine to find out if the hold up is in the same routine every time?
I had the same issue several years ago and the only thing we could attribute the scan time issue to was on line edits. as we proved the machine, we found issues and did online edits to fix the issues. the plc scan time kept getting slower. we saved the program to the pc, made a change and undid the change off line, recompiled the program and then downloaded it back to the plc. Sounds crazy, but it fixed the scan issue.
regards,
james
from a best practice point of view, what is the best way to time events over a long period. I realise that the SLC clock can drift, however 3 or...
1,624
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
259
can the slc500 5/05 send a email and text over Ethernet ?
187
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
391
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,838
