Slo Syn Warp Drive Software Needed
Jon Seagull
Jan 2012
Indianapolis
I ran into a Slo Syn Warp Drive, model # SS2000D6i, that I need to find the LATEST software for. I have Superior Electric's Motion Controller Programming Interface (MCPI) software V4.41. The compiler included with this software is TDC.dll version 1.30. Something in the drive is not working, so a new drive has been procured. With MCPI v4.41, I had no problem uploading the source code from the controller to my laptop, but when I went to download back to the replacement drive, I first had to compile the code. The compiler puked on a SAVENVR command which it didn't understand. I think the problem is that the source code was written and compiled with version 1.4 of the compiler. I don't know if this newer compiler is part of a newer version of MCPI, or perhaps some other related software, such as MotionWriter (which I have not been able to find for download). I also may be having a problem with the OS in the controller. The failed controller has version "DxI REV 1.67 09/01/99 DV14773B" in it, while the replacement drive has version "DxI REV 1.11 06/10/99 226118-001C" installed. MCPI comes with OSs that can be downloaded to the controller, but only REV 1.11 is included in what I have available.
So, ideally I'm looking for a version of software newer than 4.41, that includes version 1.4 or better of the compiler, and has REV 1.67 of the OS, so I can update the replacement drive. But realistically I'll take any information anybody can give me. 🤞🏻
Hey Jon,
I came across with the Slow Syn Warp Drive Model# SS2000D3i.
One of the unit requires some repairs and must be sent out. So I want to retrieve all the setting prior.
Unfortunately, We not have the MCPI software which came with all 4 stations.
I have contacted CTS and no luck.
Can you tell me how/where I can purchase the software.
I realize this is an old post, but worth a try.
Regards,
Rey
I am using Slo syn TDC series servo drive ( discontinued products ),now I want to replace it by DanaherMotion S600 series Servo drive with Single...
3,447
I am trying to find out some info on an slo-syn mx2000 drive plc. This one has stalled on an Movehome command and will not move. I can move it...
2,696
Hi Guys , Thanks for the quick qesponse to my last question I need all the information I can get for a motor I have and am using for a machine...
10,581
Hi, I Have A Direct Logic Dl105 Plc And I'm Trying To Drive A Stepper Motor By Using A Slo-syn D6 Driver. The Problem I Have Right Now Is That I...
1,877
Apparently there are a lot of these systems still running the field today so I thought perhaps this information might be helpful to someone in...
91
