sls5/05 on ethernet
shoeb
Sep 2008
NAGPUR
I'm having trouble getting communication with my SLC 5/05 using ethernet. I'm connected to the SLC ethernet port with a cross over cable to my laptop. The SLC 5/05 I.P. address is 100.100.100.101. My laptop I.P. address is set at 100.100.100.102 with a subnet mask of 250.250.250.0. The driver congured is the AB_ETH-1. am using RSLinx classic ver 2.51 I can't see the processor in RSLinx. When I try and go on line I get "No response from processor at selected path/node Diagnostics status failed Ox4" When i go to windows start/run/CMD I can ping the processor and it answers back. Can anybody see anything i've done wrong
When you created you Ethernet driver did you remember to put the PLC's IP address in "Station Mapping" in the Configuration? It is an easy step to miss. I will not go out and "Find" Ethernet devices you need to list them.
Good luck
Your subnet mask seems odd. I would expect it to be 255.255.255.0 Although if you can ping the SLC, that would point to the setup in RSLinx.
Thanks all of you.
now my system is communicating with my laptop, after mapping the IP address in channel configuration and changed the subnet mask to 255.255.255.0
203
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
101
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
321
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
479
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
549
