small machine plc
I have been using Automation Direct PLC's for close to ten years now. I have only had one unexplained failure, I suspect some kind of power surge or spike. The only other failures that I have seen were due to my own negligence(underating outputs). I will not use anything else unless I am forced to. Tech support is fantastic and FREE.
I
I believe that estimating (well, that is) is the most difficult task in the engineering field. Do any of you have insight to share on some...
3,547
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
622
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
818
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
372
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
16
1,433
