Good morning guys.
Im triying to communicate 4 JXC91 with a 1769-L35E AB CPU.
I already test the JXC91 with a newer AB CPU using eds files and works great.
I was researching about the connection with this older CPU so I create the JXC91 as a generic ethernet module in my program and define data type and and assembly instances as SMC indicate. (See pictures attached).
At my first try I put a wrong assembly instance and received a code error indicating invalid segment. (Wrong assembly instance number). After the correction I only received error code 16#0203, PLC try to stablish comms but without achive it.
Do you know if could be an incompatible problem because the PLC is too old? Should I use MSG instruction?
