SMX Flex busted LCD screen, how do i program parameters?
ans3288
Jul 2011
mm
hi guys!
need a lot of help!
i need to update parameters for my 150 SMC Flex, unfortunately, the lcd is cracked!!! any suggestions on how to upload my parameters? or can somebody point me to the manufacturer of the LCD display? i took it apart already, it has 30 pins...
thanks!!!
anson
You may try to use Drive Explorer Lite, that is downloadable for free, but you need an hardware interface to connect to the SMC-Flex (1203-SSS).
You may find more informations here:
29926 - Using DriveExplorer Lite, DriveExecutive, and DriveObserver with the SMC-Flex Softstarter
Or you may try to use an Hand-Held Human Interface Module (20-HIM-A3 / 20-HIM-A5), which also requires a 20-HIM-H10 cable to connect to the SMC.
See here for more infos:
31775 - Use of hand held Human Interface Module (20-HIM-A3) with SMC Flex to copy parameters to and from control modules
- fuzzy logic
fuzzy logic, thanks for the response! il try to look for the cable and il download the software, thanks!!!
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
56
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
132
Hi, I'm currently having issued with a PowerFlex 252. It was working fine last week, and suddenly decided to stop working. When I go into...
111
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
100
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
42
