Software Utility to Map PLC Network Bus Topology
mbd0722
Aug 2003
Taunton, MA
The bus cabling in the Quantum PLC network are long runs and very difficult to trace. The network asbuilts are incorrect. Is there a Schneider Modicon or third party software utility to discover and map the PLC network topology of Modbus non-redundant Cable A, Cable B as well as the Modbus Plus bus? I would like to find out what physical order the Remote I/O Quantum 140CRA93200 Drops and TSX Momentum I/O nodes are connected without having to take down the network. The PLC software loaded is Schneider Modicon Concept 2.5. Thank You
I found that since this RIO network has the drops (140CRA93100) on a modified PLC Redundant Hot Standby/Dual Cable System the Concept STAT block (Online > Controller Status > STAT: Read Controller Status Table) will not obtain the actual health status of either RIO networks on cable A, B or on the TSX Momentum I/O bus. I could have used the STAT block to help with the trace if the network topology was conventional. A third party utility would not be able to perform this function either on a RIO (not Modbus/Modbus+) network. Please correct me if I am wrong.
Hi Everyone, I need some method/tool/utility/software for breaking the password in Siemens S7-400 CPU. password protection level is 3(write/read)...
7,040
Does anyone else have an issue downloading from their Automatic updater? I typically get around 1MB/sec this is running around 70kb/sec. Is...
3,351
Hi! This is my first message in this forum, so I just want to say hallo and also share with you my freeware utility for automation software...
2,195
I have been trying to install the ENIutility software on my home computer running Windows XP Pro SP1. I get a message that my system32 can’t run a...
2,168
132
