Solenoid Air flow drawing
qwemx
Jul 2017
Earth
195
Hello !
I need help to understand these arrows on this solenoid
this solenoid is activated electrically by 110 VAC and it is being used to control a Valve .
It seems that the BOX on the right is when Spring is working and has pulled the solenoid valve to its Spring return position this is the position when there is no power on the solenoid.
and
the box on the left is when the solenoid is powered and being pulled by electromagnetic force against the spring
I suspect it's a 4/2 solenoid with a possible manual override, however I don't recognize the way it's drawn, based on standards 1 = in and in de-energised state 1 goes to 2, 4 goes to 5 (exh port) Energised 1 goes to 4 and 2 goes to 3 (second exh port). in other words it's a single acting change over.
So in context it probably goes like this, in De-energised state port 1 drives a cylinder back with air on and port 4 goes to exhaust in energised state port 2 drives a cylinder forward and port 2 goes to exhaust.
The arrows shown on left indicate it's de-energised state and the arrows on the right show it's energised state, this is shown opposite to normal convention to any drawing I have come across
#1 Mister X, I was looking for a decent pic when I noticed you had posted one.
My post got a bit muddled, (number dyslexia) but you should get the gist of what I said. Anyway Based on what most of us agree on it is a single acting solenoid valve to drive a cylinder both ways.
Hi All, Solenoid bank controls air to 8 cylinders. We used to able to move cylinder up and down by hand no problem but now there is a small amount...
2,429
May I know whether they are the same thing? Can I use a regular Solenoid air valve to gate vacuum?
4,726
Hello all, I am a beginner and am requesting some help. I have been tasked with a program in ladder logic where once the start button is pressed...
23
2,008
I have a SC9-LS24-3 surge protection solenoid cable from automation direct...
1,353
Hi Experts! I'm trying to control a solenoid valve (don't have part number, but I've been told its a 24V DC 30 watt coil) with a PLC output card...
6,603
