Ok.. we have this system in place already. We use the valve to dispense a drop of liquid onto containers travelling upto 300 per minute speed. This is our normal mode. Lets call it Mode A from now. During this mode, the valve needs around 24V to activate (as it is between 25% to 50% duty cycle). So the output of the PLC is tied to the valve directly.. Everything works well.. But soon we realized we need another mode, Mode B, when the valve has to remain open. We need to add this to make the valve dispense liquid all the time.. Of course we do not want to change much of our existing set up. If we use the same PLC output and leave it ON. The valve gets 24V at this 100% duty cycle when it requires only 13V so the valve coil gets burned.
I have lots of spare outputs on the PLC. I am looking at various options to make both modes work. In my previous post, I used a separate output and a resistor to drop down the voltage from 24V to 13V. I got several suggestons and I decided to go with using a separate 12V power supply thikning it would be easy for people to understand, troubleshoot and replace if needed.. (The valve does work with 12V to remain open)
The PLC output now decides the mode the valve needs to operate - Mode A with 24V or Mode B with 12V. Swithcing between Modes can happen often too but not as high as 300 per minute. Now, I decide to use such a scheme below. This scheme will help ensure only one of the two go to the valve and also offers isolation. But I need to look for the right products..
I am very much open to other views too to make this work. As I mentioned, we want the scheme to be reliable, easy to troubleshoot and preferably compact.
Hope this helps.. please let me know your comments/questions.
