Somachine basic in Somachine
chud
Oct 2007
KALAHARI
1,123
Hi guys
1st project with somachine and it looks like i made a hash of things. I created a project with somachine. Selected my tm221 controller and then from Central i went into somachine basic and wrote all my code.
Now the problem is it seems I should have just used somachine basic stand-alone and not from within somachine v4.1. Because via central into somachine basic i do not get the option to save or save as in basic.
So im stuck with a finished program but dont have a smbp file which will give me problems in vijeo designer linking the driver.
Anyone know if I can rescue my code somehow?
I only have SoMachine basic, so can't test this... but what if you download to the PLC in soMachine full and upload in the basic version?
Other option to try is just select all in each POU and copy paste between programs... again can't try it but i know i can do it between POUs in basic!
Thanks for the advice guys.
Shooter thanks a million.
For future reference, if you are in somachine central and select controller you have an option to import and export the somachine basic project.
Didnt even see this
Hi all, I've been trying to develop modbus rtu program between uv balasts and plc ı'have 6 slave balast.I am reading fault run voltages etc...
1,209
hello eveyrone I want to make an application with M221 PLC in SOMACHINE BASIC program. I request your valuable help. I have a 50 ms pulse...
1,612
Hi Guys, I'm using M221(TM221CE24R) PLC and SoMachine Basic from Schneider and having a bit of problem. 1. I can't able to read the data from...
1,752
Hello, I am new to plc programming. I am trying to program a flow meter (E&H promag 50) in somachine basic to achieve the following: 1...
2,413
I downloaded SoMachine Basic, I'm looking to maybe use an M241 in an upcoming project. It seems that the basic vs, doesn't offer Tag based...
3,064
