Someone out there, please tell me what this....
etherbion
Apr 2006
Malang
Hi, I'm just wanna starting of PLC cuz needed by my work. I had H2 Plant Sysmac C-200 Hg with CPU 43-E. Could someones tell me what this PLC's?
Thankyou,
etherbion
I'm sorry with my english that real bad. But I still need a help from someone who knew this machine : Sysmac C-200 Hg, it used for electrical power plant to converting hydrogen to be power electric. But I need some books of it and of course what computer peripheral that might be needed to programming this machine (need computer specification and peripheral like data cable and software)
thank you
The PLC is probably an Omron C200HG Alpha PLC.
You can find manuals here http://oeiwcsnts1.omron.com/marcom/pdfcatal.nsf/PDFLookupByLinkCode/MAN-W302-E1-09?OpenDocument
and here http://oeiwcsnts1.omron.com/pdfcatal.nsf/PDFLookupByUniqueID/92921700A28C382A86256AEF0067CAE9/$FILE/M11W303E1081203.pdf?OpenElement
If the processor is the Z type, you will require this manual http://oeiwcsnts1.omron.com/pdfcatal.nsf/PDFLookupByUniqueID/F53EAFF2C7239A748525683F00609226/$FILE/M11W322E1041003.pdf?OpenElement
I would suggest you purchase Omron CX-One programming software from your local Omron distributor and a cable part No CQM1-CIF02 to communicate with the PLC.
Thanks BobB......you're right the type PLC is OMRON C200HG, but the processor type is 43E. And thanks for your suggestion, thank a lot.....
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,105
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,599
Hello, I'm brand new to the forum and I have a frustrating problem at work that I've been trying to find a solution to. I have scanned the...
11,216
Hi, I only have the RSLogix Micro starter edition and cannot save as .SLC for the micrologix to micro800 conversion tool on CCW. I would be very...
3,704
How can the address in the picture work in the Fuji D 0304-E and not work with the Weintek HMI how does it use the -E because in the PLC program...
2,998
