Somewhat OT : Coax cable stripper
Cable thickness. 58/59/6 are all different thicknesses. There are basic strippers with a slider to set which it will cut for which just adjusts the depth of the blade set.
Without having one in hand, I would not be able to make any assumptions.
Thanks for the input!
I don't know much about the differences between RG6 and RG58.
That reference has a pdf that you can look at to see if you can adjust the screws on the blades to see if it can strip the cable as you want. I am not going to spoon feed you if you keep discounting everyone's suggestions.
PLC types have to read a lot to understand what we look at so maybe read a little more on people suggestions before making snape judgements.
Jim, I am not sure what caused your outburst.
I am NOT discounting anyone's suggestions.
I did NOT discount YOUR suggestion. I even thanked you for your first response!
I did not ask to be spoonfed.
P.S. Your reference link does not work! It tries to go to this site:
Code:
https://www.%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A/Products/RA-1786-CTK-B-UPP.aspx
I have been learning/reading about the stripping/crimping tools longer than I care to admit.
I have contacted stripping/crimping vendors and manufacturers to get info about a product that would strip a specific cable to fit a specific connector.
I have bought a couple tools that the manufacturer and vendors have made claims to the capabilities of the tools for my application. unsatisfactory.
Just throwing this out there since there may be some who aren't aware of the differences between Pozidriv and Phillips screwdrivers - or even the...
4,282
Hi group, I need a single phase 120vac speed control for a 1/2 hp gear motor, that is running a hoist on a degreaser system we are building. I...
1,831
Hi all, just wondering if there is a list of resources and locations somewhere on this site? Would this be a good thing? I happen to be in need...
1,609
I have been involved in panel design and building for nearly 18 years and have used various methods for supporting and/or rigging the panels while...
30,833
Hi. I have a HMI program made with WinCC Flexible, and it shall be displayed at an exhibition on a 43" widescreen monitor. I think it is a HDTV...
3,152
