Spectrum Controls
CENTER
Nov 2003
Long Island NY
142
Are there any problems using Spectrum controls universal analog modules with AB MicroLogix 1400 that anyone has experienced.
I've used Spectrum universal input and output cards, but it was because I had a specific signal need that wasn't covered by the standard AB modules. They work just fine except you need to take some additional programming steps to write the module configuration to the card - it doesn't configure the same way. I've never had any reliability or application problems with them though.
I used them in SLC family. Never any problems. I would probably use this if I hadn't started started down the road that if my local supply house doesn't stock multiples I try not to use them.
I am a system integrator so I had multiple customers in multiple fields. Metal stamping, robotic welding, waste water, prisons, etc. So I try to keep a low profile on the parts list I use now.
Currently I'm programming a Controls Spectrum InView P42C-SC using a ControlLogix. The display has an ethernet communications module attached to...
1,351
I need help on how to configure a spectrum controls 2080 IF4u plug in card for a micro 830 controller. I would like to use this for a 2 wire RTD...
2,375
Has anyone here ever used the spectrum controls universal i/o? http://www.spectrumcontrols.com/ I am looking at this unit for contrologix...
2,615
Does anyone know a good reliable place to purchase a 1762sc-IF8u and a OF8? The price from my distributor is good but they want 13 weeks delivery...
2,237
Anyone use them? I bought a couple and I am going to start using them to flash the firmware but since I have a IF2 in slot one and this is the...
1,475
