Speed measurement precision
naturephoenix
Jan 2015
Vienn
181
If we are measuring speed of rotating machine by measuring time between rising edges, precision is at certain frequency equal to fm/system clock frequency(fm is current frequency) . So smaller frequency better accuracy. In a case more impulses/ teets per revolution accuracy is decreasing with this method. But using method calculating number of impulses in certain time second mettod is more accurate with more teets, but how to calculate accuracy with second method?
Look:
Method 1:
EXP 1:
Measuring speed by measuring time interval between two rising edges. Let's say at frequency fm = 50Hz we are using fc = 16MHz system clock .
Accuracy is defined by Acc = (fm/fc).
EXP 2:
In a case we have 1000 rpm (50Hz) and 60 teeths, that's:
Acc = 1000Hz/16MHz
So Acc is reduced in example 2.
Method 2:
Measuring speed by counting number of impulses in fixed period of time.
EXP : 1 -> Same like in Method 1.
Acc = ??
EXP : 2 -> Same like in Method 1
Acc = ??
Acc in Exp 2 should be higher than in Exp 1 with method 2, but I don't know how to calculate it.
Hi All, I am using CompactLogix L33ER with a 1769-IQ16F card for a rotating machine shaft ( drive and driven pulley arrangement with V belts )...
2,016
I'm reading someone else manual inside which is described speed measuremnt by measuring the time in between 2 signals. It says "The 24VDC...
2,640
looking into options to do non contact speed measurement Measuring speed of rail carriages. Maximum expected speed to be measured is 1 km/hour...
1,745
I want to measure the period of a 60Hz signal with .001 Hz accuracy resolution. The Schneider M430 high speed counter BMX EHC 0200 has a...
8,246
Dear All, I want to measure speed using pulse input to Delta DVP series PLC. How do I use "SPD" instruction and how can I set my configuration for...
3,519
