Big John T
I use the following code to determine if a driver has stopped turning. The driver has a target on the shaft and a prox on the housing so the prox is on half the time and off half the time as the shaft is rotating. As the screw gets torqued the shaft stops and either the prox is on or off long enought to time out one of the timers.
Is there a way to do this with one timer?
Is there a better way?
John
John
