Splitting Encoders
benaiahhenry
Sep 2011
Corning, NY
265
So, in the last several months I have had several jobs or quotes that require splitting the feedback from a motor to several devices, such as the drive as well as a separate DAQ unit. I'm wondering how other people handle this while keeping the signals clean and without generating a lot of noise.
I'm particularly interested in doing it on AB MPL series motors since I use a lot of them. Rockwell doesn't really seem to like to talk about splitting encoder signals, so I'm wondering what other people have done.
Has anyone used something like this? http://www.amscontrols.com/products/Accessories/encoder-signal-splitter-(6390)
AB/Rockwell had an "Encoder Buffer" available as 4 or 8 way output. Don't know if they're still in production.
4100-EF04 and 4100-EF08
You can use ready made splitters or for fewer outputs you can use a number of Optocouplers:
http://uk.rs-online.com/web/p/optocouplers/5330019/
Thanks Bryan, I'll check into those.
I'd seen references to these before, but I can't find them on the AB website anymore. Up until this morning they also had a 845-BB encoder buffer up there, but now the page seems to have been taken down.
We solve this problem in a different way. Some of our encoder interfaces can be put in high impedance mode so an encoder with a differential output can drive or be the master for multiple motion controllers. The last motion controller on the encoder line must be left in the default state with the termination enabled.
What do these cost approximately? I use a custom built splitter that cost about $300. If this cost less it may be the way to go.
I am close to wits end and would appreciate any new perspective. Cannot go into minutia, but here is a rough rundown of the system and issue we...
26
9,333
I have to take a 16 bit N register and split some of the bits into separate integers. example: Bits 0-1 = integer with a value from 0-3 Bit 2 is...
22
5,945
Would it be wise / safe to split a 24vdc input from a switch to a PLC and relay? I currently have 14 of the same type of equipment that each have...
1,545
Any one know of way to split a 4-20 mA signal 4 ways? Do they even make such a device? Thanks
3,670
I have an application where I need a single SSI encoder to connect to both a safety controller (SICK Flexi Soft) and a general-purpose PLC...
2,118
