SQL & SQO Instruction
Mar 2005
Ontario
22
Hello Everyone....
Has been a while, well I am still putting along learing what ever I can on PLC's, got to give dibs to Lance1...he's been great helping me out behind the scenes!!
Anyhow.....I have 2 questions that are puzzling me, and I would sure like someone else's opinions..
Anyhow here they are
#1. Which function can not be changed/accessed on SQL instruction?
(a) File
(b) Position
(c) Destination
(d) Source
(e) Control
#2. Which function can not be changed/accessed on SQO instruction?
(a) Source
(b) File
(c) Position
(d) Control
(e) Destination
According to my opinion and others all of them can be accessed or changed....but that is not a choice !!
Any ideas?
Any one!!
Wolf
Wolf as far as the textbook goes
1. It is not the first time the answers are wrong
2. The author somewhere in the text said "you cannot change XX - because" then writes the question around that little sentance.
NOW FOR REAL WORLD
It has been a while since I looked at sequencers, BUT
assume you have two sequencer operations using the same command eithr SQO or SQL. They do entirely different things so assume all data in are different.
Given that
would not all of a thru e in the multiple choices be different?
Do you have a PLC setup yet that you can play with? If so just take 3 or 4 lites and set up a sequence (traffic signal setup is a good model) - another is a clothes washer.
Dan Bentler
Hi All, I need some clarification on sequencers, I researched this forum but haven't been able to find a good explanation, including the ones...
5,096
Hello everyone: This is my first time posting a thread to this website. I am just starting to learn PLC (RSLogix Micro Starter lite). I am now...
3,667
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
151
Hi all, I have FTV v13 installed on my VM. I made an ME application and exported it in v11, as that's the version being used on the Panelviews at...
411
Dear colleagues, I am reaching out for assistance with an issue I am having. I have a code that can successfully insert data from FactoryTalk...
1,070
