Here is a link to an application description from satel:
http://www.satel.fi/downloads/application-notes/2006/WIRELESS-PROFIBUS-DP-TOGETHER-WITH-SATEL-RADIO-MODEMS
Notice that only 9600 and 19200 baud are possible. So you must adapt your HMI accordingly.
That means, reduce the number of active tags (typically objects on a screen) and maybe the update rate has to be turned down too.
The satel devices are actually not made specifically for Profibus, but are "transparant" RS485 devices.
In the note is mentioned that the Profibus master has to be modified somewhat. This sounds like is is the same issue as with the Phoenix Contact Bluetooth devices.
If you need much faster update rates than is possible with 19200 baud, then you should look at wireless ProfiNet.
