ST (IEC 61131) Coding Question
friendlyfire
Jan 2008
Comox
Hi gang,
What a great forum, I've learned a great deal from all the posts and thoughtful responses.
I'm developing a controller using the ST language. I haven't settled on a hardware platform and am for the moment using the TwinCat software from Beckhoff to get a head start on the design. I'm impressed with the power of the language and capabilties of the software tool. I have a couple of questions about coding in ST.
a) is there a really good book that goes beyond providing an overview of IEC 61131 languages and into details of how best to implement real control solutions? I checked Amazon and saw a couple of options but it would be nice to have some recommendations.
b) I've written some code to run a counter at a variable frequency. This may become the engine generating the pulse sequence to a stepper motor. I'm used to VHDL (for gate arrays) and it is normal in that environment to pull whatever bits you need from a counter, but in ST it doesn't seem to be easy to grab just one bit. To be specific, in this case I just want to pull out the least significant bit of the counter and feed this to an ouput (so it will be a square wave at the frequency of the signal driving the counter). Optionally I will use other bits which present square waves at various divisions of the driving signal...
The counter is a WORD variable. I can write some kind of hack something like
IF INT(counter/2)*2 = counter then
pulse:=1;
ELSE
pulse:=0;
END_IF
but this seems very clumsy
Am I missing a quick way to connect one bit of a word variable to a boolean? In VHDL it would look something like pulse:=counter[0] if my memory serves correctly.
thanks
I think you can treat an integer or word effectively as a structure of bits. So:
TestInt: INT;
TestInt.2 := TestInt.1 AND TestInt.0;
TestInt bit 2 equals TestInt bit 1 and TestInt bit 0.
This type of thing builds in my copy of TwinCAT. I don't have anything to actually test it on, though.
Keith
Keith
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,182
I was poking through the Stackoverflow PLC Tag when I saw this answer to a question about converting a Real to a DWord and back again. What...
2,928
I am looking for some expert advice. I have always made function blocks both with inputs and outputs and without inputs or outputs. I make the...
21
6,825
Hello and happy new year! I would like to further understand who needs to design by this standard and is it a requirement for everyone or only...
1,794
So Ladder is easy to read graphically, most everything can be coded in ladder, and it represents wiring diagrams the closest. SCL and ST are good...
1,759
