ST SCL question (swap words)
userxyz
May 2002
any
2,768
Anyone knows how to swap 2 words in a doubleword varible in SCL or ST ?
This is what I have:
Set_Pos:= REAL_TO_DINT(GRAPH_POS_SET * Scale)
Set_Pos is a DINT, the 2 words/integers in this doubleword should be swapped.
In STL it's possible by using a ROL_DW function and this for a shift of 16 places.
In ST or SCL, I have no idea...
I also need the CAW function in SCL: Swapping 2 byte's in a word
SCL & STL implementations for swapping words in a dword.
Code:
FUNCTION FC2: VOID
VAR_IN_OUT
    dwData:DWORD;
    END_VAR
VAR_TEMP
wTemp:WORD;
dwSwap:DWORD;
wSwap AT dwSwap: ARRAY[1..2] OF WORD;
END_VAR
dwSwap:=dwData;
wTemp:=wSwap[1];
wSwap[1]:=wSwap[2];
wSwap[2]:=wTemp;
dwData:=dwSwap;
END_FUNCTION
FUNCTION FC 1 : VOID
TITLE =
VERSION : 0.1
VAR_IN_OUT
  dwData : DWORD ;
END_VAR
BEGIN
NETWORK
TITLE =
      L     P##dwData;
      LAR1  ;
      L     W [AR1,P#0.0];
      L     W [AR1,P#2.0];
      T     W [AR1,P#0.0];
      TAK   ;
      T     W [AR1,P#2.0];
END_FUNCTION
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Hello, When you want compare values of an array to a range of numbers is it a right way to do that? FUNCTION ADD VAR_IN_OUT A:ARRAY[1..50]...
2,076
I just found a piece of code using an operator "+=" IF tag1 AND tag2 THEN tag3 += tag4; tag5 := tag5 + tag6; END_IF; I don't...
4,831
I am having difficulty doing something i do in every other plc without a problem I have created an SCL AOI. I have an integer input to it. Lets...
1,613
I am new to PLC programming. Is there a standard way to incorporate alarms / warnings / events such as the exceptions in C++ or Java where you can...
1,990
