Stage programming and a total run timer
MiPilot
Nov 2009
Michigan
27
I have written a program using stages (using Do-More) for the first time. The machine performs a repetitive task and the program is working great.
The program consist of three stages. The initial stage 0, I tasked it to empty the machine without permitting any fill operations. This is because I have no way of knowing the level of the tanks. It then transitions to stage 1 which allows tank 1 to fill and tank 2 to empty. A count down timer is started and when finished it moves to Stage 2. This stage empties tank 1 while filling tank 2. When finish it transitions back to stage 1. This continues until the machine is turned off or a e- stop is activated which reverts back to stage 0.
I have also programed a C-more panel. Within the monitor, I have included a total cycle counter as well as a total run timer. This is where I am having an issue.
Also X25 and X26 are coming from the touch panel.
Will the counter/timer work the way it is written?
Thanks Steve
Assuming stages S3 and S4 are enabled then it appears the counter and timer should behave as you describe. Using the simulator they appear to continue to count/time after reaching the preset (even when the preset is zero). What 'issue' are you having?
For one thing: Don't use X's as inputs from a touch screen. X bits are written to by physical Inputs on each scan. Also I am not sure what Y13 is, But it 'appears' you may be using Y13 just as a bit for running the timer. If Y13 is also being used as a physical output, then what you are doing is probably fine.
You need to use C bits for all internal Coils and contacts.
Use X's only for Physical inputs, and Y's only for physical outputs.
Hope this helps.
:D
Thanks guys....
I found out the hard way that the x bit did not work from the screen. I changed them to c bits and the resets work fine.
Also, when I read the instructions on programming the timers with stages, it led me to believe I needed to address the the contacts as $Main.S0, but that didn't work. I changed them to just S0, S1, S2 and the counters and timers worked as they should.
Also, when I read the instructions on programming the timers with stages, it led me to believe I needed to address them as $Main.S0 but that didn't work. I changed them to just S0, S1, S2 and the counters and timers worked as they should.
$MAIN.S0 is referencing the bit for Stage 0 in the program block MAIN.
When you type S0 inside a program block it automatically references that Program blocks own stage bits (ie: $Process_Run.S0)
Glad you're making progress.
After reading all about the advantages the Stage programming could have, finally I come to the practical question: where are the stage instruction...
4,320
So I've decided to start branching out a bit more and look into another PLC programming package. Based on the popularity of it, I decided to try...
4,252
Does anyone with experience on Automation Direct/Koyo PLCs know what classification that "Stage" programming falls under? I have used these tings...
1,959
Ok, to me this would be considered a firmware bug. I use stage and block programming heavily in my programs. I always assumed all stage bits in a...
3,234
I'm just starting to learn AD stage programming. (newbbie-ish) Fanuc ladder programming mainly. While I see MAJOR advantages with using stage, I...
19
9,562
